Bezier handle moving both points
Albo
Post by Albo »
Hello,
I'm trying to adjust a bezier handle.
All the point move together. How can we move only one side of the handle ?
In other software (not animation) if you hold the option key (on Mac)
you will only move that part of the bezier.
Thank you.
Hoptoad
Re: Bezier handle moving both points
Post by Hoptoad »
On Mac, hold the option key down while you drag the handle. The other handle, as well as the point itself, will not move. I don't know why it's not working for you. Are you sure you are seeing handles and not actual points? Having a lot of points can get confusing.
Albo
Post by Albo »
Thanks.
That is exactly what I am doing.
I quit Moho and opened it.
It now works.
Mysteries of software...
I think there's a bug that makes it appear like you're working with show Bezier is on, but Moho is actually behaving like the handles are off. I've run into this a few times since 13.5 was released but I'm not sure what triggers it. So far, it seems to occur randomly. As you discovered, quitting Moho and restarting corrects this issue.
I reported this a while back so hopefully it will get fixed in an upcoming release.
