I had just made my first animation (no, not a bouncing ball one! A full legth one with characters), but when I played it, it stopped at frame 72 on the timeline! I know there is a way to make the timeline last longer, but I don't know how. Does anybody know how? If you know how, can you please teach me how?
All help is greatly appreciated.
Sincerely, Avalanche
Go past frame 72?
- Avalanche941
Go past frame 72?
"Good" thinks itself "good", but "evil" thinks itself "good" also. "Evil" thinks "good" is "evil", and vice versa. You think "good" is "good" simply because it is better for your welfare.
- Víctor Paredes
maybe if you go to the video properties... where it say start frame and end frame. just put:
start frame 0
end frame 0
the animation will have all frames you want.
start frame 0
end frame 0
When you create a new Moho project the default length is 72 frames.
I make this mistake all the time... do a preview or render and forget to change the length.
You can change the length in the Project settings, or in the final render. Looking at the project settings there is a box for the end frame of the animation... or the length I forget off hand.
What I do is use the key command to set the final frame. On a Mac you hold down:
Command + Option and click on the frame of the timeline you want to be the end point. I don't know the equivelent on the Windows versiion.
You can also set the end frame on the final render settings.
-Vern
-Vern
Option and click is enough.heyvern wrote:Command + Option and click on the frame of the timeline you want to be the end point.
In most cases, these "modifier keys" are each other's equivalent in Windows and Mac
Option <--> Alt
Command <--> Ctrl
Control click <--> right click
Shift <--> Shift
I wrote in most cases, because X11 (the XServe equivalent of Linux on the Mac) uses Control instead of Command, because the PC keyboard doesn't have a Command key.
Edit: Technically, the latter thing isn't true. In fact, the Command key on an Apple keyboard is the same as the Windows key on a PC keyboard. Something to remember if you connect a PC (usb) keyboard to an Apple computer.
- Avalanche941
