what is UUID?
davoodice2
what is UUID?
Post by davoodice2 »
any help?
Stan
Re: what is UUID?
Post by Stan »
davoodice2
Re: what is UUID?
specifically in moho
GetLayerByUUID():
Stan
Re: what is UUID?
Post by Stan »
The "regular" layer ID is just the ordinal number of the layer. It may change if you move the layer above or below other layers. And that's what is used by the MohoDoc:Layer(id) or MohoDoc:LayerByAbsoluteID(id).
Unlike that, the UUID is a unique identifier. You can use it to make sure the particular layer is the one you need regardless of its position in the document.
There's no GetLayerByUUID method though. However, the UUID is used in some rare cases. Take a look at this example: GroupLayer:GetLayerOrdering().
davoodice2
Re: what is UUID?
Stan wrote: Thu Sep 02, 2021 8:06 am The "regular" layer ID is just the ordinal number of the layer. It may change if you move the layer above or below other layers. And that's what is used by the MohoDoc:Layer(id) or MohoDoc:LayerByAbsoluteID(id).
thanks.very clear description.
