3D Texture Bug (SOLVED)
DK
Post by DK »
Hi.
I've not been around for a bit. Been in hospital but well enough to start creating with Moho again and found what I think is a bug.
If you 3D lathe out an object and surface it with an image texture you get this really bad image noise happening when it's animated.
The only way I could reduce the effect was to split the curves but it didn't go away just got a little less jittery.
Cheers
D.K
Re: 3D Texture Bug
Could you share the file and/or texture image?
It looks like one side of the lathe is crossing the other.
DK
Re: 3D Texture Bug
Post by DK »
Sorry for the late reply. Didn't receive a reply notification.
Link below.
http://www.creativetvandmedia.com/Forum/MohoTest.zip
Cheers
D.K
Re: 3D Texture Bug
Yeah, it's what I thought the problem likely was: http://www.filedropper.com/mohotestfixed
3D vectors are lathed around the x-axis, so I just added a line down the x-axis and deleted one side. How you had it, both sides where lathed, so they kept wanting to overlap each other.
DK
Re: 3D Texture Bug
Post by DK »
Hi Wes. Fantastic thanks for solving that mate :)
Cheers
D.K
