rt_next_keyframe - prev
davoodice2
Post by davoodice2 »
any body can edit theses script to skip hided bones. I want it acts like ctrl+alt+Right or left arrows. but this script calculate hide bone key frames to.
I want this two script only, not complete tool. simply for assign shortkey. ctrl+alt+arrow are extremely bad shortkeys and useless for me.
thanks friends
rt_next_keyframe
-- Provide Moho with the name of this script object
ScriptName = "RT_NextKeyframe"
RT_NextKeyframe = {}
function RT_NextKeyframe:Name()
    return "Go to next keyframe"
end
function RT_NextKeyframe:Version()
    return "0.1"
end
function RT_NextKeyframe:Description()
    return "Go to next keyframe for current layer"
end
function RT_NextKeyframe:Creator()
    return "Rudiger"
end
function RT_NextKeyframe:UILabel()
    return("Next keyframe")
end
-- The guts of this script
function RT_NextKeyframe:AllChannelsHasKey(channels, global_channels, start_frame, end_frame, moho)
    -- Check whether any channels have keyframe in the given frame range
    local doc
    local found_key = false
    local incr
    local layer = moho.layer
    local timing_offset
    if end_frame > start_frame then
        incr = 1
    else
        incr = -1
    end
    if layer.TotalTimingOffset ~= nil then
        timing_offset = layer:TotalTimingOffset()
    else
	timing_offset = 0
    end
    -- Go through next/previous frames and stop when a keyframe is found
    for frame = start_frame, end_frame, incr do
        for i, channel in ipairs(channels) do
           if channel.HasKey ~= nil and channel:HasKey(frame) then
               found_key = true
               break
           end
        end
        if found_key == false and global_channels ~= nil then
            for i, channel in ipairs(global_channels) do
                    found_key = true
                    break
                end
            end
        end
        if found_key then
            moho:SetCurFrame(frame-timing_offset)
            break
        end
    end
    return found_key
end
function RT_NextKeyframe:Run(moho)
    local doc
    local current_frame
    local channels
    local channel
    local i
    local global_channels
    if moho.layerFrame ~= nil then
        current_frame = moho.layerFrame
    else
        current_frame = moho.frame
    end
    -- Modify to only detect point keys
    --channels = RT_Utilities:get_point_channels(moho)
    -- Get all layer and global channels
    channels = RT_Utilities:get_layer_channels(moho, moho.layer)
    if layer:CurrentAction() == "" then
        global_channels = RT_Utilities:get_global_channels(moho)
    end
    -- Do it in two stages as running AnimDuration takes a while
    local found_key = RT_NextKeyframe:AllChannelsHasKey(channels, global_channels,
                                                        current_frame+1, current_frame+20, moho)
    if found_key then
        return
    end
    local anim_duration = moho.document:AnimDuration()
                                      current_frame+21, anim_duration, moho)
    -- **ToDo: Figure out how to update Frame indicator
    moho:UpdateUI()
end
rt_prev_keyframe
ScriptName = "RT_PrevKeyframe"
RT_PrevKeyframe = {}
function RT_PrevKeyframe:Name()
    return "Go to previous keyframe"
end
function RT_PrevKeyframe:Version()
    return "0.1"
end
function RT_PrevKeyframe:Description()
    return "Go to previous keyframe for current layer"
end
function RT_PrevKeyframe:Creator()
    return "Rudiger"
end
function RT_PrevKeyframe:UILabel()
    return("Previous keyframe")
end
function RT_PrevKeyframe:Run(moho)
    local doc = moho.document
    local current_frame
    local frame
    local channels
    local channel
    local i
    else
    end
    channels = RT_Utilities:get_layer_channels(moho, layer)
    end
    -- Check whether there are any keys to the left of the cursor
    RT_NextKeyframe:AllChannelsHasKey(channels, global_channels, current_frame-1, 0, moho)
    moho:UpdateUI()
end
Re: rt_next_keyframe - prev
https://mohoscripting.com/classes/M_Bone#fHidden to tell which bones are hidden.
https://www.lostmarble.com/forum/viewto ... 12&t=31612 for a scripting example of which keyframes go with which bones.
davoodice2
synthsin75 wrote: Wed Aug 25, 2021 8:00 am https://mohoscripting.com/classes/M_Bone#fHidden to tell which bones are hidden.
thanks.
I updated rt_utilities.lua
old
if not RT_NudgeKeysLeft.nudge_selected_bones_only or bone.fSelected then
new
if ((not RT_NudgeKeysLeft.nudge_selected_bones_only or bone.fSelected) and not bone.fHidden )  then
