help to solve problem
davoodice2
Post by davoodice2 »
hi I am newbie in moho scripting. and I cant find good resource for learning. I do some script before in other softs.
please help me to learn.
in this simple code i have 2 problem
1 . after press button moho message for create group you must first name it !
2 .line82 attempt to index field mohox (a nil value).
I want just return frame number.
and I want do this with call a function with press button..
and what is 'moho' into prentices.
-- Provide Moho with the name of this script object
ScriptName = "bbb"
bbb = {}
function bbb:Name()
	return self:Localize('UILabel')
end
function bbb:Version()
	return '1.0'
end
function bbb:UILabel()
end
function bbb:Creator()
	return 'bbb'
end
function bbb:Description()
	return self:Localize('Description')
end
function bbb:ColorizeIcon()
	return true
end
-- Is Relevant / Is Enabled
function bbb:IsRelevant(moho)
	return true
end
function bbb:IsEnabled(moho)
	return true
end
-- bbbDialog
local bbbDialog = {}
bbbDialog.BUTTON_1 = MOHO.MSG_BASE
function bbbDialog:new()
	local d = LM.GUI.SimpleDialog(bbb:Localize('UILabel'), bbbDialog)
	local l = d:GetLayout()
	d.button1Button = LM.GUI.Button(bbb:Localize('Button 1'), d.BUTTON_1)
	l:AddChild(d.button1Button, LM.GUI.ALIGN_LEFT, 0)
	return d
end
function bbbDialog:HandleMessage(msg)
	if msg == self.BUTTON_1 then
		bbb:nnnnn()
	else
	end
end
-- The guts of this script
function bbb:nnnnn(moho)
	local mohox = moho
	local dlog = bbbDialog:new(moho)
	dlog:DoModeless()
	frameN = self.mohox.frame
	print(frameN)
end
function bbb:Run(moho)
	dlog:DoModeless()
	moho.document:SetDirty()
	moho.document:PrepUndo(nil)
end
-- Localization
function bbb:Localize(text)
	local phrase = {}
	phrase['Description'] = ''
	phrase['UILabel'] = 'bbb'
	phrase['Button 1'] = 'Button 1'
	local fileWord = MOHO.Localize("/Menus/File/File=File")
	if fileWord == "Файл" then
	end
	return phrase[text]
end
Re: help to solve problem
For #2, this is a bug that cropped up in 13.5.
On line 55, trying using: MOHO.MSG_BASE + 1
For #1, this is because bbbDialog:HandleMessage(msg) doesn't have access to "moho" to pass along to bbb:nnnnn(moho).
davoodice2
synthsin75 wrote: Wed Aug 18, 2021 11:02 am For #2, this is a bug that cropped up in 13.5.
thanks master. is there any solution for 2?
davoodice2 wrote: Wed Aug 18, 2021 11:04 am
I assume you mean for #1 (sorry, I answered them backwards).
This is a long standing problem for modeless dialogs. They don't have a readily available way to access "moho," which is why very little is done with modeless dialogs.
davoodice2
All my dreams were dashed. :? :?
davoodice2
I changed this part
	local mohox = moho
	print(frameN)
end
	dlog:DoModal()
end
change modeles
but same error exist.
Since a dialog's HandleMessage doesn't have access to "moho", you need to define d.moho in the dialog's new().
ScriptName = "bbb_test"
bbb_test = {}
function bbb_test:Name()
end
function bbb_test:Version()
	return '1.0'
end
function bbb_test:UILabel()
end
function bbb_test:Creator()
	return 'bbb_test'
end
function bbb_test:Description()
end
function bbb_test:ColorizeIcon()
	return true
end
function bbb_test:IsRelevant(moho)
	return true
end
function bbb_test:IsEnabled(moho)
	return true
end
-- bbb_testDialog
local bbb_testDialog = {}
bbb_testDialog.BUTTON_1 = MOHO.MSG_BASE + 1
function bbb_testDialog:new(moho)
	local d = LM.GUI.SimpleDialog(bbb_test:Localize('UILabel'), bbb_testDialog)
	d.moho = moho
	d.button1Button = LM.GUI.Button(bbb_test:Localize('Button 1'), d.BUTTON_1)
	return d
end
function bbb_testDialog:HandleMessage(msg)
		bbb_test:nnnnn(self.moho)
	else
	end
end
function bbb_test:nnnnn(moho)
	frameN = moho.frame
	print(frameN)
end
function bbb_test:Run(moho)
	local dlog = bbb_testDialog:new(moho)
	dlog:DoModal()
end
-- Localization
function bbb_test:Localize(text)
	local phrase = {}
	phrase['UILabel'] = 'bbb_test'
	end
	return phrase[text]
end
But this self.moho will not update until the dialog is reopened.
davoodice2
thank you so much.
