How to use shortcut key smart action ?
amour_et_animation
Post by amour_et_animation »
Hello everyone,
(Sorry for my bad English, I am French :? .)
I'm trying to use the shortcut keys in the action window, but they don't work. I don't understand why. Maybe I'm using this function wrong.
Could someone help me?
Re: How to use shortcut key smart action ?
Action shortcuts work while playing the timeline. But there's a few things to be aware of. For them to work well, all of the points, bones, etc. need to be keyframed in the actions, so you don't end up with odd interpolation between keyed and unkeyed bits. The actions will not show up in the workspace/timeline as you're playing the timeline and applying them with the shortcuts. They show as soon as you stop playing the timeline. I don't remember if older versions of Moho handled updating the workspace any better.
Also, the actions are applied with hold keyframes, so they act like step interpolation between each. You'll need to delete the hold keys if you want them to interpolate.
amour_et_animation
This is even better than I thought I could do with this feature. Real time is great! Thanks a lot for your help synthsin75 :D
But there is another thing I don't understand, why my character's bones can't be moved once my references are set with the shortcut? Whereas when I use "insert the reference" to insert my action, I don't have this problem.
Maybe you accidentally made one action a smart bone action? That would control all the keyframed bones, keeping you from controlling them.
Otherwise, it seems to work fine here.
amour_et_animation
Yes, you were right, that was the problem. Thanks again for your help!
Just a guess. Glad it worked.
MrMiracle77
Post by MrMiracle77 »
Are shortcut keys for actions still available in 13.5?
- Dave
(As Your GM)
MrMiracle77 wrote: ↑Wed Sep 01, 2021 10:17 am Are shortcut keys for actions still available in 13.5?
Yeah, I double checked before answering. If you want to add a shortcut to an existing action, renaming it will bring up the dialog.
