Target Bone Switch
TrikiNya
Target Bone Switch
Post by TrikiNya »
You can toggle target bone using switches!
  1. Smart bone dial (set it so the positive and negative angles aren't separate)
  2. One keyframe where the target is set
  3. Another keyframe immediately after that untargets the bone
  4. Mainline
  5. Test it in the Bone Manipulation tool (works on frame 0)
nya
Re: Target Bone Switch
True! Nice tip, and can be extended to "you can keyframe almost everything on Moho, and every thing that you can keyframe, you can control with a smartbone".
This video complements your explanation very nicely:
https://www.youtube.com/watch?v=sPgbqGG0mtc
TrikiNya
Post by TrikiNya »
Daxel wrote: Fri Aug 06, 2021 8:56 am can be extended to "you can keyframe almost everything on Moho, and every thing that you can keyframe, you can control with a smartbone".
The power of Moho!
nya
