Easier Line Width & Scale Compensation Control
arglborps
Post by arglborps »
For better, easier and more flexible line/stroke width control of final rigs, I'd like to se the following improvements:
1) It would be nice if you could toggle scale compensation in one click for all layers contained inside a folder/bone layer/switch layer without having to check the box on EVERY. SINGLE. LAYER. IN. A. RIG if you want to switch it on or off for a whole rig.
2) There should be a way to easily increase/decrease line width for all contained layers ad hoc – basically the same that the free Adjust Line Width Script does:
http://mohoscripts.com/script/sz_adjust_line_width
This should be part of normal Moho functionality.
3) "Normalize Layer Scale" should also be applied to all layers contained in a folder/switch layer/bone layer and not just ignored if you apply to these non vector layers.
Kilian Muster
Designer (day job), Animator/Creator (in the after hours)
PiXELBLAST Production BlogYouTube Vlog
