Script idea: create a bone between two coordinates
moe33
Post by moe33 »
Hi everyone, I have a idea for a script: Get two position coordinates and create a bone between the two coordinates. A bit like DUIK.
I made a script by myself. I'm really sorry that I don't know how to write code at all. The script is made entirely by copy and paste...
This script can only get the coordinates of two points, and then create a bone.
Maybe the code looks messy, but luckily it can be used.
But I hope it can have more functions, such as getting the center coordinates of a shape or the center coordinates of a layer.
If you can, please help me improve this script...
Thank you very much!
https://drive.google.com/drive/folders/ ... sp=sharing
gilcartunista
Re: Script idea: create a bone between two coordinates
Post by gilcartunista »
Hi moe33...Thank you!!! I use Moho 11, and it works beautifully!!! Grateful!!! For your enormous generosity! Grateful!
SimplSam
Post by SimplSam »
I know the Grid (View > Enable Grid) is not so good, but did you try using that to get your bones to snap?
I know we definitely need better Snapping support for all 'draw/transform' tools.
Thanks for the script!
I use the "divide" feature on the select points tool frecuently to create a point in the middle of other two for things like these where I want something centered.
moe33
Post by moe33 »
SimplSam wrote: Thu Aug 05, 2021 12:11 pm I know the Grid (View > Enable Grid) is not so good, but did you try using that to get your bones to snap?
Yes, I have tried to use the grid, but it is troublesome.
So I want to use a script to get the coordinates in order to accurately build the bones.
You can try to use my script, it can accurately build bones between two points.
animationfan
Post by animationfan »
moe33 wrote: Wed Aug 04, 2021 7:02 am Hi everyone, I have a idea for a script: Get two position coordinates and create a bone between the two coordinates. A bit like DUIK.
Hey Moe33. downloaded your script "bone between two coordinates" but it shows "missing resource image" error! please rectify.
SimplSam
Post by SimplSam »
animationfan wrote: Mon Dec 16, 2024 10:55 pm Hey Moe33. downloaded your script "bone between two coordinates" but it shows "missing resource image" error! please rectify.
I have checked the version at: https://moeu33.notion.site/Set-A-Bone-B ... 735e353b0a
And everything is there. The content of Tool\ should be copied to your <Custom Content Folder>\Scripts\Tool\ folder and the content of ScriptResources\ to your <Custom Content Folder>\Scripts\ScriptResources\ folder.
Note: If you have already had the error for "missing resource image", then you will need to restart Moho after you have the placed images folder 'mu_set1bone' in the right place.
animationfan
SimplSam wrote: Tue Dec 17, 2024 8:05 am
THANKS SimplSam. It worked yesterday and didn't know what right thing I did! deleted some files and I broke it again. Thanks a ton Simplsam for highlighting the correct way. Its up and working flawlessly. Cheers!
