Hi
Set Time Line visibility at layar comp menu does'nt work.
also this option and tow option above it does'nt exist on documentation.
set time line visibility does'nt work
- davoodice2
Re: set time line visibility does'nt work
You need to click the Expose Timeline Visibility button (the stopwatch) at the bottom of the window to activate the saved Timeline Visibility settings for the selected Layer Comp. If you prefer to use the right-click menu, you need to select the equivalent command (Expose Timeline Visibility).
If you're not seeing the changes you make to your Layer Comps, make sure you're clicking the Update Selected Layer Comp(s) button at the bottom, or use the right-click menu equivalent (Update).
- davoodice2
Thanks. I think it sets visibility of layerGreenlaw wrote: ↑Wed Aug 04, 2021 8:10 am You need to click the Expose Timeline Visibility button (the stopwatch) at the bottom of the window to activate the saved Timeline Visibility settings for the selected Layer Comp. If you prefer to use the right-click menu, you need to select the equivalent command (Expose Timeline Visibility).
