Undo Script Tool?
J. Baker
Undo Script Tool?
Post by J. Baker »
Is there an "Undo Script" Tool for drawing tablets?
Lukas
Re: Undo Script Tool?
Post by Lukas »
Not tested this, but you could try this. Save it as LK_Undo.lua in your tools folder. If it works you can also create a redo button next to it, just change all instances of 'undo' into 'redo'
-- Provide Moho with the name of this script object
ScriptName = "LK_Undo"
LK_Undo = {}
function LK_Undo:Name()
	return "Undo"
end
function LK_Undo:Version()
	return "0.1"
end
function LK_Undo:Description()
	return "Undo"
end
function LK_Undo:Creator()
	return "Lukas Krepel, Frame Order"
end
function LK_Undo:UILabel()
	return "Undo"
end
function LK_Undo:IsEnabled(moho)
	return true
end
function LK_Undo:IsRelevant(moho)
	return true
end
function LK_Undo:ColorizeIcon(moho)
	return true
end
-- The guts of this script
function LK_Undo:Run(moho)
	moho.document:Undo()
end
J. Baker
Post by J. Baker »
Thanks! I tried but it doesn't work. It shows an "unknown" icon in "Other" tools panel but when clicked, no response.
Lukas
Post by Lukas »
J. Baker wrote: Tue Aug 03, 2021 12:24 pm Thanks! I tried but it doesn't work. It shows an "unknown" icon in "Other" tools panel but when clicked, no response.
Ah I see
ScriptName = "Undo"
should have been:
I updated the previous post, it should run now 🙂
J. Baker
Post by J. Baker »
Thank you very much! :D
Lukas
Post by Lukas »
No problem!
You know what, here's both undo and redo with icons, I see how this would be useful for tablets:
J. Baker
Post by J. Baker »
Here's a zip file with the LUA, PNG icons, Read Me, and Moho document...
http://www.posemotion.com/download/LK_Undo.zip
J. Baker
Post by J. Baker »
That's funny! We were thinking the same thing. I made new icons though. :D
Lukas
Post by Lukas »
Ha 😉 nice
J. Baker
Post by J. Baker »
I renamed the "Undo" files, so that the Undo icon shows before the Redo icon in Moho. It's "LK_1_Undo" now.
Lukas
Post by Lukas »
J. Baker wrote: Tue Aug 03, 2021 2:21 pm I renamed the "Undo" files, so that the Undo icon shows before the Redo icon in Moho. It's "LK_1_Undo" now.
Actually, you can quite easy edit the order the tools are shown in by editing the _tools_list.txt file in the tools folder. So you don't have to change the names to re-order them.
Also, you can have the icons be greyed out if there's nothing to undo/redo by changing the IsEnabled function to this:
	if moho.document:IsUndoable() then
		return true
	end
	return false
end
(I updated/reuploaded my .zip)
J. Baker
Post by J. Baker »
Very nice! Thanks!
SimplSam
Post by SimplSam »
Lukas wrote: Thu Aug 05, 2021 12:25 am ... Actually, you can quite easy edit the order the tools are shown in by editing the _tools_list.txt file ...
The recommended way is to use the GUI: Edit > Preferences > Tool Layout (even though it is painful if you want to move a lot of stuff around!).
Moho 14.3 » Win 11 Pro 64GB » NVIDIA GTX 1080ti 11GB
Moho 14.3 » Mac mini 2012 8GB » macOS 10.15 Catalina
J. Baker
Post by J. Baker »
Interesting. Thanks!
