Moho 13.5 exported video audio menu disappear
opeth
Post by opeth »
Hi All,
We use some exported Moho video's on other project. Today i noticed. When i imported mp4 file ( which i rendered on 13.5 ) i couldnt see audio menu on layer setting.
Can you please check it, I will report accordingly.
Moho 14.2 MacBook Pro 16'2 M1 Max 32gb.
Re: Moho 13.5 exported video audio menu disappear
If you're importing an mp4 into a Moho project, Moho can no longer handle mp3 audio encoding. This is a known limitation in v13.5.
You'll need to import the audio as wav, ogg, aiff, etc.. You can import the mp4 video into Audacity and export to either wav or ogg.
opeth
Post by opeth »
We use .Wav audio on moho project. we had to reuse the file after rendering . I've seen before on the forum that it doesn't support mp3 format but we use mp4 video format not .mp3 . Also in project we use .wav audio format .
Even though you used wav for your project, rendering to an mp4 video encodes the included audio as mp3. That's just how mp4 works.
opeth
Post by opeth »
I didn't know it worked like that. We will continue our work by adding it as a wav to the file again. Thank you very much for the information you provided.
