Dial Bone AND normal bone
- Diana Kennedy
I'd like to know if there is a way top control a group of layers with a Dial AND an normal bone.
As an example : I make a head. A dial bone controls the mouth (to talk) but when I ad a second, a normal bone in order to move the head, either the dial bone doesn't work properly anymore, either the normal bone doesn't. In short : its a mess. I am pretty sure that it can be done but I'm doing something wrong. But what?
Re: Dial Bone AND normal bone
I'm guessing you're using the regular bone to layer-bind the head group/bone layer. Layer-binding stops smart bones (dials) from reaching any layer inside the bound group/bone layer. This means that you'll need to release all the intervening group layers and bind all the sublayers to the normal bone (thanks to nested layer control, which should be enabled by default).
If it continues to give you trouble, you can PM me a file and I can show you what it looks like.
- Diana Kennedy
Okay, here's what you have:
Head bone layer with regular bone to control the head
- Kopf bone layer with smart bone to control the mouth
- - vector layer art
- - etc..
It's the smart bone in the Kopf layer that is keeping the regular head bone from reaching the layers nested in the Kopf layer. To fix this, you'll want to:
1. Copy and paste the "talk" smart bone from the Kopf layer to the Head layer.
2. Select all the Kopf sublayers and drag them into the Head layer.
3. Delete the Kopf layer.
- - etc..
- Diana Kennedy
In fact, so that there are 2 bones in the same bone layer, one smart dial and the other normal?
I tried this once but it resluted in the entire head moving around when I actioned the dial bone and in weird movements when I actionned the normal bone.
Or did I get it wrong?
Yes.Diana Kennedy wrote: ↑Sun Jun 20, 2021 9:19 am In fact, so that there are 2 bones in the same bone layer, one smart dial and the other normal?
If the regular bone was parented to the dial bone, it would move oddly and the dial bone would also move it. Make sure those bones are not parented together.I tried this once but it resluted in the entire head moving around when I actioned the dial bone and in weird movements when I actionned the normal bone.
- Diana Kennedy
Ok, that may have been the problem. Thank you so very much
Feel free to ask if it gives you any more trouble.
Also check to make sure the Bone Strength is Zero for the Smart/Dial bone.Diana Kennedy wrote: ↑Sun Jun 20, 2021 9:19 am I tried this once but it resulted in the entire head moving around when I actioned the dial bone and in weird movements when I actionned the normal bone.
