Moho to Grease Pencil
dueyftw
Post by dueyftw »
I just started to play around with Moho export to Blender's Grease Pencil.
If you export a Moho FBX into Grease Pencil it will not work because Moho FBX output is ASCII and Blender uses binary.
A converter can be found here:
https://www.autodesk.com/developer-netw ... r-archives
I used two files from the Moho library.
Gorilla And the results
https://srv-store5.gofile.io/download/a ... orilla.png
I was have trouble the the hierarchy. but if that is a problem just move the layer in the z direction one step in the 3d space.
The other was Kukulkan in Moho.
Some of the more complex layers with masking did not import along with particles.
https://srv-store6.gofile.io/download/3 ... /snake.png
I hope this helps and do post here anything you feel to add.
And the animation was also imported with the fbx converter.
Dale
