Hello.
First, I apologise if this is in the wrong bit.
I use Moho 12 but would like to fire up my copy of Anime Studio Pro 11.
But I can't.
It says I'm running in demo mode and, when I "Insert Serial Number", it says I have exceeded the number of activations... which I haven't as it's only on one PC.
Unfortunately, I can't seem to get through to Smith Micro whose support email address appears to have been deleted.
Could anyone, please, advise me?
Thank you.
Anime Studio Pro???
Re: Anime Studio Pro???
You are not alone. see also: http://www.lostmarble.com/forum/viewtop ... =5&t=33844
Moho 12 and under are discontinued, and the license service no longer works.
If you head over to: https://my.smithmicro.com, you will be able to download and install the final available version of your Anime Studio / Moho - which will allow you to continue its use.
Moho 14.3 » Win 11 Pro 64GB » NVIDIA GTX 1080ti 11GB
Moho 14.3 » Mac mini 2012 8GB » macOS 10.15 Catalina
SimplSam... thank you very much.
May I ask?... should I uninstall my version of ASP 11, first, before installing the Final Version, please?
And, since my Moho 12 is working perfectly, would it be better (i.e. safer) to leave it? As support has ended, I'm a bit nervous. And I can't upgrade to 13 as I'm using W7.
Please forgive my ignorance.
- hayasidist
even if you don't have immediate plans to install them, I strongly advise you to get all the "final versions" for which you have a valid licence key from the SM site before it goes away.
http://www.lostmarble.com/forum/viewtop ... =5&t=33574
IMO, it's a good idea to remove it first and then re-install with the new version, especially if it's been years since you installed and last used it. This removes the chance of working with corrupted program files.BarryS wrote: ↑Sat Jun 12, 2021 12:03 pm May I ask?... should I uninstall my version of ASP 11, first, before installing the Final Version, please?
If you're running the original release of Moho 12, I'm surprised to hear it's still working for you. Or are you using the final version? If not, you can expect your version of 12 to expire any day now because the Smith Micro license server is no longer active. If you haven't updated 12 to the final version yet, I highly recommend doing so. As with ASP 11 above, you should probably do a clean install just for the peace of mind.
Also, if you're really using 12.0 and not 12.5 (the final version), the upgrade is definitely worth it. 12.5 is much more stable and has a number of improvements over 12.0.
I agree with Hayasidist, if you haven't grabbed all of the final installers for Moho 12.5 and earlier from Smith Micro's website, better do so now and store the files in a safe place. They're not going to be available forever because Smith Micro no longer owns Moho.
From here on out, Moho 13.5 and above will be available only from Lost Marble of course.
Dear hayasidist and Greenlaw,
Thank you very much for your advice. Greatly appreciated.
I have done as you suggest... downloaded (and backed-up) the final versions.
Actually, it appears that I have already upgraded 12 to 12.5, so that's fine... plus the safety-net of having downloaded 12.5... just in case.
Once more, many thanks!
I had that problem a while ago. I suspect it was a result of using a VPN, but not totally sure. For some reason, when I tried to reinstall from the same installation file I had saved, it wouldn't work and I'd get the error you speak of. I had to go to the website and download a fresh copy of anime pro 11
I'm more afraid of you than you are of me
Smith Micro shut down their activation servers, which is why they offered the final build installers (that don't check in with a server).dragonmaya wrote: ↑Sun Jun 13, 2021 7:04 pm I had that problem a while ago. I suspect it was a result of using a VPN, but not totally sure. For some reason, when I tried to reinstall from the same installation file I had saved, it wouldn't work and I'd get the error you speak of. I had to go to the website and download a fresh copy of anime pro 11
