I use a Mac and Moho 13.5. For creating SVG I'm using Affinity Designer.
Its not possbile to Import SVG, neither via General Import nor Vector -> SVG. There is even no error message. Via general Import I only see a box with questionark.
I read the "file name" discussion, but there is no foreign char in the SVG-file. Is there a known bug on Mac? Or is there a workaround?
Regards,
Carsten
Failed to import SVG
Re: Failed to import SVG
Foreign characters anywhere in the path to the file can cause the same problem.
