Moho 13.5 render from V12.5 output black video
ManleonardoMX
Post by ManleonardoMX »
When I heard about the update of Moho to V 13.5 I jumped to the new version with a project already started in V12.5, but I had many problems with the change, especially with unexpected crashes, when I work the animations files, but the most worrying thing is that when I render files that I started in V12.5 the renders come out black, with audio, but in the preview everything looks correct... I do not know how to report this bug, so I ask in the forum if anyone has similar problems.
SimplSam
Re: Moho 13.5 render from V12.5 output black video
Post by SimplSam »
Hi. This black video might be due to a known buglet in the new software, and is related to non-english characters in the export filename or filepath. Try renaming the export output file/path.
see also: http://www.lostmarble.com/forum/viewtop ... =5&t=33978
ManleonardoMX
Thank you, I'm sure that's the problem, because it happens in a project I'm doing with three languages, and the problems are just in Spanish and french, this folders are called "Español" and "français"
