Blurry components...
hgdagr8one
Post by hgdagr8one »
While working in ASP9 I ran into an issue. There are layers of my character's body that are blurry when they are previewed but I want them clear.
What setting is making certain parts blurry?
Please if anybody can help me with this issue I would be greatly appreciated it.
Re: Blurry components...
Maybe some layers have Blur Radius enabled? Check the layers or groups and make sure the value is 0. If this is the case for a lot of layers, select all the layers and then click the '...' at the top of the Layers window to open the layer properties. Now set Blur Radius to 0 and enable 'Copy All Settings...' at the bottom of the window, and click Apply. (Note: This option applies the same settings to all selected layers, so make sure this is what you really want. You can undo this, BTW.)
If that's not the case, maybe Depth Of Field is on? Open Project Settings and there is a check box for that.
hgdagr8one
Greenlaw wrote: Sun May 16, 2021 2:03 pm Maybe some layers have Blur Radius enabled? Check the layers or groups and make sure the value is 0. If this is the case for a lot of layers, select all the layers and then click the '...' at the top of the Layers window to open the layer properties. Now set Blur Radius to 0 and enable 'Copy All Settings...' at the bottom of the window, and click Apply. (Note: This option applies the same settings to all selected layers, so make sure this is what you really want. You can undo this, BTW.)
The blur radius is at 0. Depth of Field was on. And when I turned it off it cleared the blurriness. Thank you.
Cool! Glad that worked for you!
