How do I add frames at the beginning of an animation
How do I add frames to the beginning of an animation? Lets say I've got a character in a particular pose on frame 1. Let's also say I've already done a bunch of work on the animation, and discover I really need the pose on frame 1 to stay in "hold" for 24 frames, but it unfortunately starts moving right after frame 1. How would I insert 24 frames of "hold time", from frames 1 to 24... before the action starts. I'm using Moho 12. This seems like it should be really easy to do. Any ideas ?
Re: How do I add frames at the beginning of an animation
Animation>Rescale Keyframes
Add 24 to new start and end frames.
Thanks for the reply. I'm really looking at wanting to add 24 frames to the beginning that exactly match frame 1. If I rescale 1-2 as 1-24 the software will add the 24 frames, but within those 24 frames, it will include the changes that exist between frames 1 and 2. What I assume would work perfectly, would be if I could use 1-1 (instead of 1-2) as my beginning range, that way the 24 frames will be added without any changes... but the software will not allow me to do that. Maybe I can figure out some kind of "work around". I messed up not creating at least a few " frames, before my action starts at the beginning, but the software is a little "unforgiving" in this particular area. Unless I'm still missing something... which experience tells me, is totally possible.
I figured out a pretty good "work around". I copied the entire document on frame 1 to frame 2, then I was able to rescale 1-2 to 1-24 without picking up any changes. I love this software.
