Vitruvian bones: Selecting bones - question answered.
strider2000
Post by strider2000 »
I'm just trying out Moho 13.5 and am very interested in the Vitruvian bones (I remember Victors post, that's probably the genesis of it). This post started out as a question, but as I was typing I figured out my answer, so I thought I'd share my findings in case others are looking into this great new feature :)
Is it possible to select a bone underneath a bone?
Simple answer is yes.
For my first test I create an arm and a foreshortened arm. However, I unthinkingly created them such that the upper arms were aligned on top of each other. The implication is that when I created the bones, one upper arm was on top of another. That should have been my first clue, since I had to hide bones to do it. In any case, I then moved to creating the Vitruvian group and realized I couldn't select the bone underneath the top one.
Solution:
The bones are drawn as outlines, just select one bone then either ctrl-click or shift-click the other bones you want to group. Make sure you click on the bone outline, rather than clicking inside the bone. If you click inside, it will always select the one that's on top.
Discussion
In my initial attempt I seemed I didn't seem to be able do it. In retrospect, I was clicking on the inside of the bone, not on the bone outline itself. But, you might say, "My bones are very closely aligned and it's difficult for me to click on them independently." The base of the bone may be aligned, but there should be some part of the bone that is easily distinguishable. They shouldn't both/all be pointing in the same direction and have the same length. If they do, then that should be the base/common bone for your group (See the tutorial).
strider2000
Re: Vitruvian bones: Selecting bones - question answered.
Thought it might be interesting and helpful to see, what I guess, is the genesis of the Vitruvian bone tool, super cool :) Victor's switch bone video.
http://www.lostmarble.com/forum/viewtop ... =9&t=30445
I'm watching it again to see the kinds of way in which Vitruvian bones can work really well.
Thanks @Victor Paredes! Your rigging and animation are awesome!
