Hi All,
I think I found bug.
For example, open a layer on frame 100 and make a square shape. Then
Open new layer again and make different square again(chane position a little bit ) . If you group two layers, one layer becomes invisible. If I go 1 frame forward and come to the same place, the error gets better .
Layer disapper bug Moho 13.5
Moho 14.2 MacBook Pro 16'2 M1 Max 32gb.
Re: Layer disapper bug Moho 13.5
Yes slightly odd. For some reason the 2nd created layer (or any layer created at non-frame-0) becomes temporarily hidden when Grouped (with selection) in that manner.
I also tried with v12.5 and v13 and they don't have the problem.
You can report the problem at: https://lostmarble.com/support
yes you are right. We were using moho 13 and it wasn't a problem I just created a ticket.SimplSam wrote: ↑Wed Apr 28, 2021 8:59 am Yes slightly odd. For some reason the 2nd created layer (or any layer created at non-frame-0) becomes temporarily hidden when Grouped (with selection) in that manner.
