Masks problems in MOHO 13.5 (SOLVED)
negroclarito
Post by negroclarito »
I'm so happy to try the new 13.5 version.... but... I just opened a file created in the last 13.02 and all the masks are broken. Anyone having the same problem? .
All masks already have many actions and animations so create new ones will be a problem.
I'm using windows 10 version.
I can't show the full character. I add some images of the detail of the mouth.
Last edited by negroclarito on Wed Apr 28, 2021 12:42 pm, edited 3 times in total.
Re: Masks problems in MOHO 13.5
negroclarito wrote: Mon Apr 26, 2021 1:58 pm I'm so happy to try the new 13.5 version.... but... I just opened a file created in the last 13.02 and all the masks are broken. Anyone having the same problem? .
You may need to enable/disable GPU acceleration to match what you had it set to in 13.0.
opeth
Post by opeth »
You should uncheck under the menu of 'display quality - GPU accelaration
Moho 14.2 MacBook Pro 16'2 M1 Max 32gb.
negroclarito
PERFECT!!. It worked.
Thank you!!
OMG. I've been using MOHO for many years and I didn't know that. Is that the same in Mac?. Before I always use Mac and I never have to uncheck that.
For the rest of things in MOHO 13.5 to say that everything works more fluent. I'm so happy with this new update.
Tradley
Post by Tradley »
Mac user here.
Seems to work okay.
Who says Moho is worse than Adobe Flash?!
