HS Shape - new version **UPDATED** now v9.55
A new version of my "shapes" tool is now available.
https://www.mediafire.com/file/kwnt64df ... 5.zip/file
In response to a request, this adds an option to create multiple lines radiating from an origin (as well as having them parallel)
The .zip has the installation folder (for scripts / install script) and a readme.
============================ original post about the 9.50 version ==============
https://www.mediafire.com/file/ibpv6hpd ... 0.zip/file
changes since the previous version (9.02) are:
One new subtool: Bone influence shape.
New options for creating a grid of rectangles (one fill / one mesh shape as before or now separate fills/strokes for each rectangle)
Options to create multiple straight lines.
it's been nearly 5 years since 9.02 and I'm really glad to see that Moho has emerged from the wilderness ...
(for previous versions / AS11 and earlier support please see: http://www.lostmarble.com/forum/viewtop ... 21#p167789)
Re: HS Shape - new version 9.50
Immediately installed. This is one of my "must have" tools.
Thank you! Downloaded and installed!
Lukas
Post by Lukas »
Thanks for sharing! This will definitely be useful 👍
Franky1966
Post by Franky1966 »
Hmm, how do I install this script? Can't find my way out here. I'm on a Mac.
The following info is for Windows, but I think it's mostly relevant for Mac too.
Use the Install Script command from the Scripts menu, and point it to the folder containing the two script folders (ScriptResources, tool). The command will place the scripts and icons in their appropriate places in your Custom content folder.
Alternatively, you can do this manually by dragging the contents of those folders to the locations 'ScriptResources' and 'tool' in your Custom Content Folder. To access the Custom Content folder, select File: Open Custom Content Folder. Then open the Scripts folder to see these locations.
If you didn't set a CCF when you first launched Moho, you can do that from Preferences. I suggest choosing a folder that's always accessible to your computer. (For example, a folder in Documents is a good place. I don't know what this would be called on Mac, but it can be any folder really.)
When adding custom scripts and mods to Moho, you should always do this to the Custom Content folder, and not to the Moho program folder. (Otherwise, you're altering the original program files, which you really don't want to do.)
To use the HS Shape tool, you need to first select a vector layer.
Tip: I like to make a backup copy of my Custom Content Folder before adding stuff to it. This way, if something goes wrong, I can easily regress.
SimplSam
Post by SimplSam »
hayasidist wrote: Thu Apr 15, 2021 3:30 am A new version of my "shapes" tool is now available.
Excellent tool (set of tools). I have used them many times. Thanks for the update.
I recently used it to create spokes for a bicycle wheel, using the polygon tool and deleting the outer rim edges. It would be great if, in a future +5 years time version, a similar 'spoke' option were available, either working from the principle of the Polygon -or- the MultiPointLine with angular and possibly center offset.
p.s. Is there any reason why there is a minimum of 3 points on a multipoint multiline (instead of 2)?
SimplSam wrote: Fri May 14, 2021 9:14 pm ... Is there any reason why there is a minimum of 3 points on a multipoint multiline (instead of 2)?
:D -- 2 works fine. I think it was because an earlier version only drew one line -- and there was no need for a tool to do the same as an the factory "add point" but it never got changed when I added multiple lines ....
That's the link to 9.55 it has the 2 point and the radial option for lines ... turned out to be pretty straightforward (which always worries me because if it didn't spectacularly fall over during testing, I worry that there's some glaring error still in there that I missed)
SimplSam
Re: HS Shape - new version **UPDATED** now v9.55
Post by SimplSam »
Amazing - Thanks so much. This works perfectly.
