Help: Weld the two closest loose selected endpoints of unclosed curves
Lukas
Post by Lukas »
Hi everyone,
I could use some help on this code. What I'm trying to achieve is:
When you've got multiple unclosed curves, you can select a couple of endpoints (or just two entire curves), and the script should find the two selected endpoints closest to each other and weld them together.
So basically, it should weld the two closest loose selected endpoints.
So far I've got this code, and it works correctly in some cases, but in other cases it welds the points completely wrong and I can't seem to figure out why. I think the mistake has something to do with the "attachSeg" variable that I'm not getting right, but I'm kind of lost... 😑 If you try it with a couple of random unclosed curves you'll see it immediately.
local mesh = moho:DrawingMesh()
moho.document:PrepUndo(moho.drawingLayer)
moho.document:SetDirty()
-- * Find end points:
local endpointIDs = {}
local endpoints = {}
for i = 0, mesh:CountPoints() - 1 do
	local pt = mesh:Point(i)
	if (pt.fSelected) then
		if pt:IsEndpoint() then
			table.insert(endpointIDs, i)
			table.insert(endpoints, pt)
		end
	end
end
local shortestDistance = 9999999
local movingPointID
local solidPointID
local movingPoint
local solidPoint
for i = 1, #endpoints do
	local firstEndPoint = endpoints[i]
	for j = 1, #endpoints do
		local otherEndPoint = endpoints[j]
		if firstEndPoint ~= otherEndPoint then
			if firstEndPoint:Curve(0) ~= otherEndPoint:Curve(0) or #endpoints == 2 then
				local distance = FO_Utilities:Distance(moho, firstEndPoint.fPos, otherEndPoint.fPos)
				if distance < shortestDistance then
					shortestDistance = distance
					movingPoint = firstEndPoint
					solidPoint = otherEndPoint
					movingPointID = mesh:PointID(firstEndPoint)
					solidPointID = mesh:PointID(otherEndPoint)
				end
			end
		end
	end
end
local pos = mesh:Point(movingPointID).fPos
-- * Find curve to attach copied point to:
local movingCurveID
local solidCurveID
for i = 0, mesh:CountCurves() - 1 do
	local curve = mesh:Curve(i)
	local curveID = mesh:CurveID(curve)
	if movingPoint:IsPointOnCurve(curveID) then
		movingCurveID = curveID
	end
	if solidPoint:IsPointOnCurve(curveID) then
		solidCurveID = curveID
	end
end
-- * Find curve and edge to attach new point to: TODO is this part wrong???
local attachCurveID
local attachSeg
attachCurveID, attachSeg = solidPoint:GetEndpointEdge(attachCurveID, attachSeg)
attachSeg = attachSeg + 1
-- * Add new point:
mesh:AddPoint(pos, attachCurveID, attachSeg, 0) -- * M_Mesh:AddPoint(pos, attachCurveID, attachSeg, frame, correctBezierHandles, preserveCorners)
local newPoint = mesh:Point(mesh:CountPoints()-1)
local newPointID = mesh:PointID(newPoint)
-- * Weld points:
print ("___welding:___")
print ("- movingPoint: "..movingPointID.." on curve "..movingCurveID)
print ("- solidPoint: "..solidPointID.." on curve "..solidCurveID)
print ("* newPoint: "..newPointID.." on curve "..attachCurveID.." (segment "..attachSeg..")")
mesh:WeldPoints(movingPointID, newPointID, 0)
-- *** Peak corners:
-- * Peak new point:
newPoint:SetCurvature(MOHO.PEAKED, moho.drawingLayerFrame)
newPoint:ResetControlHandles(moho.drawingLayerFrame)
-- * Peak existing end point:
solidPoint:SetCurvature(MOHO.PEAKED, moho.drawingLayerFrame)
solidPoint:ResetControlHandles(moho.drawingLayerFrame)
Any suggestions or pointers are appreciated!
Re: Help: Weld the two closest loose selected endpoints of unclosed curves
References FO_Utilities:Distance, not included.
Lukas
Post by Lukas »
synthsin75 wrote: Tue Apr 06, 2021 1:05 pm References FO_Utilities:Distance, not included.
Ow, missed that one... It's this:
-- Get distance between vectors
function FO_Utilities:Distance(moho, vector1, vector2)
	local distance = vector1 - vector2
	distance = math.abs(distance:Mag())
	return distance
end
I see the error. I guess my first question would be why do you even need to mess with segments at all? Shouldn't it just be checking for selected, endpoint proximity, add a point, and weld it to the other?
At first I thought ClosestPoint would work, but you can only ignore one point ID at a time with that.
I don't know that this method is very bulletproof, as I haven't tested in extensively, but this is one idea:
	local pt, pt2
	for i=0, mesh:CountPoints()-1 do
		pt = mesh:Point(i)
		if (pt.fSelected and pt:IsEndpoint()) then
			local pos = pt.fPos
			local cid = mesh:ClosestPoint(pos, i, -1, true)
			local cpt = mesh:Point(cid)
			if (cpt.fSelected and cpt:IsEndpoint()) then
				pt2 = cpt
				break
			else
				local count = 1
				while true do
					pos = cpt.fPos
					cid = mesh:ClosestPoint(pos, cid, -1, true)
						break
					else
						count = count + 1
						if (count == moho:CountPoints()) then
							break
						end
					end
				end
					pt2 = cpt
					break
				end
			end
		end
	end
	mesh:AddPoint(pt.fPos, mesh:PointID(pt2), frame)
	mesh:WeldPoints(mesh:CountPoints()-1, mesh:PointID(pt), frame)
Lukas
Post by Lukas »
synthsin75 wrote: Tue Apr 06, 2021 3:17 pm I guess my first question would be why do you even need to mess with segments at all? Shouldn't it just be checking for selected, endpoint proximity, add a point, and weld it to the other?
Ow jackpot, I really didn't know what I was doing.
Thanks Wes!
You're code is definitely more elegant and honestly harder to wrap my amateur head around. I tried it and had some trouble with some extra things I didn't mention. I wanted to exclude endpoint welding if they are part of the same curve. Unless no other endpoints of other curves were selected. That way you can use the script to close a single curve, but only if a single curve is selected, otherwise it would always weld 1 curve to another, even if their own endpoints are closest.
So now I'm doing it this way and it works! Thanks for your help as always!
				end
			end
		end
		local movingPointID
		local solidPointID
		local movingPoint
		local solidPoint
						end
					end
				end
			end
		end
		-- * Add point:
		mesh:AddPoint(pos, mesh:PointID(movingPoint), 0)
		-- * Weld point:
		mesh:WeldPoints(newPointID, solidPointID, 0)
		movingPoint:SetCurvature(MOHO.PEAKED, moho.drawingLayerFrame)
		movingPoint:ResetControlHandles(moho.drawingLayerFrame)
		-- * Select entire curve:
		self:HandleMessage(moho, view, self.FLOOD_SELECT)
		-- * Update widgets:
		self:UpdateWidgets(moho)
Yeah, I only tested that on a pretty simple case, but I'm glad I was able to help. :wink:
