Using PNG or TIFF
Albo
Using PNG or TIFF
Post by Albo »
Using Moho 11.
When I import PNG's and TIFF images is it possible to add bones to the images.
I can't seem to be able.
Thanks.
Re: Using PNG or TIFF
Sure, it should work.
In ASP 11, imported images are bound with Flexi-bind by default.
Note that an image layer is only be affected if the layer is a child layer of a Bone layer, so make sure the images are actually inside the Bone layer and not just sitting under the Bone layer. Also, your bones need to have strength above 0 (it should already have some strength unless you intentionally reduced it to zero.) Another thing you can check is that Warp Using Bones is enabled in the image layer's settings. (This should be enabled by default.)
Finally, you can try selecting all your image layers and choosing Reset All Bone Rigging from the Bone menu. This will reset the layers to Flexi-bind. (Of course, any image layer still needs to be a child layers of a Bone layer to be deformed by bones.)
If none of the above solves the issue, it would help to see a screen cap of your setup, or a project file demonstrating the issue.
Franky1966
Post by Franky1966 »
Hello Albo
Did you put the images in a Bonelayer? That should do the trick.
Albo
Post by Albo »
Thank you both.
I will try this out and keep you posted.
