The light window is not working for me
ScienceAnimator
Post by ScienceAnimator »
Has anybody had trouble with the light window?
I have created a cube on a 3D layer and I am trying to change the light source. When I open the light window, all the settings are grayed out as if I'm not on a 3D layer. It doesn't seem to matter what frame I'm on (frame zero or other). I can't figure out what I'm doing wrong...
I am using Moho Pro Version 13.0.2 build 610.
SimplSam
Re: The light window is not working for me
Post by SimplSam »
ScienceAnimator wrote: Fri Nov 20, 2020 5:54 am I have created a cube on a 3D layer ...
Do you mean you converted a vector layer to 3D?
As far as I know - the light feature will only work with imported 3D objects (.OBJ's).
ScienceAnimator
Ahh, thank you SimplSam.
I imported a 3D object from Custom Content and the light window works on this layer.
