Why does the d*****s grid changes?
Jajajajack
Post by Jajajajack »
I wanted to get into the program again. And while I was just trying to resize a single line that started to resize the grid too.
And for some reason the bone layer's grid is off from the shape's layer.
Why? What the heck can I do so the grid stays in one place and size always regardless off which layer I'm on?
Re: Why does the d*****s grid changes?
Nothing, unfortunately. Moho doesn't have a general grid, it's a separate grid for each layer.
Workaround: create your own grid in a layer.
Also, you probably don't want to be using transform layer to resize a line. Better to use transform points and save layer transforms for animation, if possible.
Jajajajack
Well that's dumb. I thought it would be common sense to make the grid fixed in place. Anyways Thanks for the answers!
