scaling group when using sketchy effect
redsib
Post by redsib »
hello , i use moho 12.5 .
i have a problem with sketchy effect and scaling character .
when i use this effect in project setting :
and scale the character with transfer layer tools or even zoom out camera the effect was wiggleing but if i scale vector shape its ok .
i try unchek (scale compensation)
and ( normalize layaer scale )
but having not luck :(
i have lots of characters in lots of vector layers rigged and animated and i couldnt change every vectror size . ( and i dont want to use noisy fills and animated noise )
what can i do ? any suggestion ? :idea:
Re: scaling group when using sketchy effect
I think normalize layer scale only works with scale compensation enabled.
redsib
Post by redsib »
synthsin75 wrote: Tue Jul 07, 2020 10:22 am I think normalize layer scale only works with scale compensation enabled.
i try that and still no luck :(
Production tip (too late for you): if you need a certain design effect on your lines, you must test the method in different situations like scaling complete characters, have differently scaled objects in the same scene, and so on. You may end up with 2 or 3 different versions of characters (for close-up, normal, wide angle) in order to maintain a consistent design.
Have you tried to render one of the scenes in double resolution?
