Button script to swap the view to Wireframe and back
Stan
Post by Stan »
A button-script to quickly change the view to Wireframe and back.
If you want a different mode than Wireframe, you can easily alter it inside the script file (lines 49-51 will guide you through).
Download here: http://mohoscripting.com/uploads/1/sz_s ... w_mode.zip
velu
Re: Button script to swap the view to Wireframe and back
Post by velu »
Is it possible while working "Transform point tool" if we press "swap view mode" (with assigned shortcut key) and when release return to "Transform point tool" selection instead of "swap view mode" tool selection.
Many thanks.
I love Moho
Thanks Stan!
Stan
Post by Stan »
velu wrote: ↑Mon Jun 01, 2020 1:50 am Is it possible while working "Transform point tool" if we press "swap view mode" (with assigned shortcut key) and when release return to "Transform point tool" selection instead of "swap view mode" tool selection.
Many thanks.
That's exactly how it works now. Isn't it?
velu
Post by velu »
Thank you very much San!
It is working what I expected.
I love Moho
toonscale
Post by toonscale »
Thanks for the script. really handy but would have been nice if we could define our wireframe view cos i personally would like to have *STROKES showing.
Stan
Post by Stan »
toonscale, you can easily customize the script for your own preferences.
Open the script's .lua file with a "plain text" editor (I recommend Notepad++), and find the following line:
SZ_SwapViewMode.modeToSwap = MOHO.LDQ_WIREFRAME
(If your text editor is capable of showing line numbers, it's line 51)
So, to make it strokes instead of wireframe, change the line to the following:
SZ_SwapViewMode.modeToSwap = MOHO.LDQ_OUTLINES
The entire list of available options can be found here: http://mohoscripting.com/modules/MOHO#L ... ay_quality
You can combine multiple options using a plus sign, for example:
SZ_SwapViewMode.modeToSwap = MOHO.LDQ_OUTLINES + MOHO.LDQ_LABELS
velu
Post by velu »
Hi, When selecting "swap view mode" image layer also hiding. Is it possible only the selected object will be in wireframe mode like layer visible on/off.
I love Moho
Stan
Post by Stan »
velu wrote: ↑Mon Jun 08, 2020 12:00 am Hi, When selecting "swap view mode" image layer also hiding. Is it possible only the selected object will be in wireframe mode like layer visible on/off.
You can try changing the line 51 to:
SZ_SwapViewMode.modeToSwap = MOHO.LDQ_WIREFRAME + MOHO.LDQ_IMAGES
velu
Post by velu »
Hi San,
Thank you very much!
I love Moho
