Tutorial 2.1 - Examples of bad welding.
abraxis
Post by abraxis »
The last two images (call them images of a crown and potato) in tutorial 2.1 show the bottom of a crown removed with the delete edge tool, and the end points welded to the potato. The crown is filled with yellow at the end.
How is that done? When I weld the points, the crown is not a closed shape. When I select the edge of the crown with the Create Shape tool, it only selects the edge that was originally part of the crown; the edge that is now "shared" with the potato is not selected. If I shift-select the shared edge, then everything is selected, but the crown is still not a closed shape, and cannot be filled.
Rai López
Post by Rai López »
HI! But... have you read this?
Manual writer (probably LM) wrote:Then, weld the newly-created endpoints onto the lower shape.
If you do that, your crown will be a closed form ready to be filled, and remember that there is a lot of ways to can select only the points that you want, pressing Ctrl for use Lazo is one of they i.e., and remember you can hold pressed Alt key too to avoid select all the points of a shape when you click over it :) ...CIAO!
myles
Post by myles »
Hello abraxis,
you can shift-click individual points to include or exclude them from a shape.
I've put up a quick visual walkthough.
Regards, Myles.
-- Groucho Marx
abraxis
Thank you
Post by abraxis »
Myles,
That was an amazingly clear explanation, and now I also know about Wink!
