optimal image resolution and sizes inside MOHO
ChrisH
Post by ChrisH »
I would like to know the optimal image resolution and sizes that you can use inside MOHO when importing psd files and any other image type file.
Best,
Chris H.
Re: optimal image resolution and sizes inside MOHO
It's simple: you have your project dimensions: HDTV 1920 x 1080, so a background for this should be of the same size or a bit larger. If you want to zoom in, you need larger bitmaps.
I have my assets sorted in 3 groups:
1. everything 1:1, that's for scenes where there's no zoom or pan.
2. double size, that's for short zooms
3. if I need a real close up of something I create a new bitmap in the appropriate size.
ChrisH
Post by ChrisH »
Thank you for your response:)
I understand the general rule of what you explained, but the reason why I was asking about max size and resolution in MOHO is because I had a psd file with size 21131 x 9183 with a resolution of 200 which I used for going from a wide shot to extreme close up in Moho , but when I created the close up and render it in moho the background becomes pixelated even though i didn't push all the way in on the close up.
