Slower bone rotation?
Manu
Post by Manu »
For my liking, the bone rotation-tool reacts too much to the mouse-movements. I had a look at the lm_rotate_bone.lua script and didn't understand much of it.
Would it be possible to make the bone-rotation-tool slower and if so, could someone give me a hint as to how that would have to be done?
Rasheed
Post by Rasheed »
I don't understand what you mean. The tip of the bone follows the mouse vector. If you want the bone to rotate slower, you simply move your move vector slower. If your mouse vector moves too fast, you need to adjust your mouse system settings.
Hiddicop
Post by Hiddicop »
I'm not sure I understand what you mean...
The further away from the bones orgin (where the two inner lines cross eachother), the "slower" the bone is rotated. If you click at the very cross it's almost impossible to control the bone, but the further away you click, the more precise it gets.
rylleman
Post by rylleman »
This buggered me too a while ago (you can't get very subltle bone rotations with the rotation tool) so I started to modify the rotation tool to rotate 1/10 of it's normal movement (and some other bling-bling as well). there are a lot of work still to be done to it, it behaves somewhat irratical and I probably won't have the time to make a full workable version anytime soon but if you would like to give it a try I could put together a version and mail you so you could develop it further.
Manu
Post by Manu »
rylleman wrote:This buggered me too a while ago (you can't get very subltle bone rotations with the rotation tool) so I started to modify the rotation tool to rotate 1/10 of it's normal movement (and some other bling-bling as well). there are a lot of work still to be done to it, it behaves somewhat irratical and I probably won't have the time to make a full workable version anytime soon but if you would like to give it a try I could put together a version and mail you so you could develop it further.
So did you get the 1/10th movement to work? The rest is probably of lesser interest to me.
If only I could figure out where in the script the mouse-movement is put into the bone-tip movement, but my little bit of experience with BASIC isn't much of a help here.
Rai López
Post by Rai López »
Hiddicop wrote:The further away from the bones orgin (where the two inner lines cross eachother), the "slower" the bone is rotated.
Not always... have you tried to rotate several bones at a time in this way?
rylleman
Post by rylleman »
Manu wrote:So did you get the 1/10th movement to work?
Well, it rotates 1/10 but the problem is that when you grab the bone it makes a jump with a few degrees so it's not usable yet. I'll see if I can get it to work tomorrow.
Manu
Yippeeee
Post by Manu »
Just like yourself, I tried all sort of stuff, but always got those jumps. But I think I cracked it now. At the moment it halfs the speed at which the bones react. These are the lines where it happens:
if (moho.frame == 0) then
				local angle = bone.fAnimAngle:GetValue(0) + math.atan2(v2.y, v2.x)/2 -- Slowed down
				bone.fAnimAngle:SetValue(0, angle)
			else
				bone.fAngle = bone.fAngle + math.atan2(v2.y, v2.x)/2 -- Slowed Down
			end
It's the division by 2 that does it, but you can of course change it to another value.
The other one is the reaction-speed of the scrollwheel in the numerical field:
self.angle:SetWheelInc(1)--Slowed Down
In the original script it reads 5 between the brackets.
Manu
Post by Manu »
...and here is the whole script:
-- Provide Moho with the name of this script object
ScriptName = "LM_RotateBone"
LM_RotateBone = {}
function LM_RotateBone:Name()
	return "Rotate Bone"
end
function LM_RotateBone:Version()
	return "5.0"
end
function LM_RotateBone:Description()
	return "Rotate bone (hold <shift> to constrain)"
end
function LM_RotateBone:Creator()
	return "Lost Marble"
end
function LM_RotateBone:UILabel()
	return("Rotate Bone")
end
-- Recurring values
LM_RotateBone.selID = -1
LM_RotateBone.lastVec = LM.Vector2:new_local()
-- The guts of this script
function LM_RotateBone:IsEnabled(moho)
	if (moho:CountBones() < 1) then
		return false
	end
	return true
end
function LM_RotateBone:OnMouseDown(moho, mouseEvent)
	local skel = moho:Skeleton()
	if (skel == nil) then
		return
	end
	moho.document:PrepUndo(moho.layer)
	moho.document:SetDirty()
	if (moho:CountSelectedBones() < 2) then
		for i = 0, skel:CountBones() - 1 do
			skel:Bone(i).fSelected = false
		end
		local id = mouseEvent.view:PickBone(mouseEvent.pt, mouseEvent.vec, moho.layer, false)
		skel:Bone(id).fSelected = true
	end
	local selCount = 0
		local bone = skel:Bone(i)
		if (bone.fSelected) then
			self.selID = i
			selCount = selCount + 1
				bone.fTempPos:Set(bone.fAnimPos:GetValue(0))
				bone.fTempLength = bone.fLength
				bone.fTempAngle = bone.fAnimAngle:GetValue(0)
			else
				bone.fTempAngle = bone.fAngle
			end
		end
	end
	if (selCount > 1) then
		self.selID = -1
	end
	moho:UpdateBonePointSelection()
	mouseEvent.view:DrawMe()
	moho:UpdateSelectedChannels()
	self.lastVec:Set(mouseEvent.vec)
end
function LM_RotateBone:OnMouseMoved(moho, mouseEvent)
		return
	end
				bone.fAnimPos:SetValue(0, bone.fTempPos)
				bone.fLength = bone.fTempLength
				bone.fAnimAngle:SetValue(0, bone.fTempAngle)
			else
				bone.fAngle = bone.fTempAngle
			end
		end
	end
	skel:UpdateBoneMatrix()
			local origin = LM.Vector2:new_local()
				origin:Set(0, 0)
					bone.fRestMatrix:Transform(origin)
				else
					bone.fMovedMatrix:Transform(origin)
				end
			else
				origin = moho.layer:Origin()
			end
			local v1 = self.lastVec - origin
			local v2 = mouseEvent.vec - origin
			v2:Rotate(-math.atan2(v1.y, v1.x))
			else
			end
				while angle > 2 * math.pi do
					angle = angle - 2 * math.pi
				end
				while angle < 0 do
					angle = angle + 2 * math.pi
				end
				bone.fTempAngle = angle
				if (mouseEvent.shiftKey) then
					angle = angle / (math.pi / 4)
					angle = (math.pi / 4) * LM.Round(angle)
				end
			else
				if (bone.fConstraints) then
					local min = bone.fAnimAngle:GetValue(0)
					local max = min + bone.fMaxConstraint
					min = min + bone.fMinConstraint
					bone.fAngle = LM.Clamp(bone.fAngle, min, max)
				end
					bone.fAngle = bone.fAngle / (math.pi / 4)
					bone.fAngle = (math.pi / 4) * LM.Round(bone.fAngle)
				end
				bone.fAnimAngle:SetValue(moho.frame, bone.fAngle)
				moho.layer:UpdateCurFrame()
			end
			bone.fAngle = bone.fAnimAngle.value
		end
	end
end
function LM_RotateBone:OnMouseUp(moho, mouseEvent)
		return
	end
	if ((moho.frame > 0) and (moho:CountSelectedBones() > 0)) then
			end
		end
		moho:NewKeyframe(CHANNEL_BONE)
	end
	self.selID = -1
end
function LM_RotateBone:OnKeyDown(moho, keyEvent)
	LM_SelectBone:OnKeyDown(moho, keyEvent)
end
-- Tool options - create and respond to tool's UI
LM_RotateBone.CHANGE = MOHO.MSG_BASE
LM_RotateBone.RESET = MOHO.MSG_BASE + 1
LM_RotateBone.DUMMY = MOHO.MSG_BASE + 2
LM_RotateBone.SELECTITEM = MOHO.MSG_BASE + 3
function LM_RotateBone:DoLayout(moho, layout)
	self.menu = LM.GUI.Menu("Select Bone")
	self.popup = LM.GUI.PopupMenu(128, false)
	self.popup:SetMenu(self.menu)
	layout:AddChild(self.popup)
	layout:AddChild(LM.GUI.StaticText("Angle:"))
	self.angle = LM.GUI.TextControl(0, "000.0000", self.CHANGE, LM.GUI.FIELD_FLOAT)
	layout:AddChild(self.angle)
	self.reset = LM.GUI.Button("Reset", self.RESET)
	layout:AddChild(self.reset)
end
function LM_RotateBone:UpdateWidgets(moho)
		return
	end
	MOHO.BuildBoneMenu(self.menu, skel, self.SELECTITEM, self.DUMMY)
	if (moho:CountSelectedBones() > 0) then
		local selCount = 0
		local angle = 0
				angle = angle + bone.fAngle
			end
		end
		self.angle:SetValue(math.deg(angle) / selCount)
	else
		self.angle:SetValue("")
	end
		self.reset:Enable(false)
	else
		self.reset:Enable(true)
	end
end
function LM_RotateBone:HandleMessage(moho, view, msg)
		return
	end
	if (msg == self.RESET) then
					bone.fAnimAngle:SetValue(moho.frame, bone.fAnimAngle:GetValue(0))
				end
			end
			self:UpdateWidgets(moho)
		end
	elseif (msg == self.CHANGE) then
					bone.fAngle = math.rad(self.angle:FloatValue())
				end
			end
		end
	elseif (msg >= self.SELECTITEM) then
			skel:Bone(i).fSelected = (i == msg - self.SELECTITEM)
		end
		moho:UpdateUI()
	end
end
