Big lag and freeze ups
Jkoseattle
Post by Jkoseattle »
I'm working on a new machine which is supposedly beefier than my old one. I opened a big project, which I know is probably processor intensive, and during playback the animation freezes up occasionally and lags behind the audio track. If I pause it, wait a few seconds, and resume, it's better for a bit, but then lags again. Also, I noticed this project took a lot longer to load than it did on the old machine. The project is animating several dozen images, there are a few very active switch groups using simple vectors, there's some transparency, and two particle layers, but which only fire once though. What's weird is that my old machine, which I assumed I was upgrading from, never had this issue. Is there a setting I need to tweak? This is still a vanilla install of Moho for the most part.
Re: Big lag and freeze ups
Mac?
Jkoseattle
Not a Mac.
Windows 10, Surface Pro, i5 chip, 16Gb RAM. However, I do see now that my old machine says CPU runs at 3.10 Ghz, while the new one is 1.10 Ghz (only 12 Gb RAM on the old one though). I bet that's it, right? Anything I should be doing Moho setup-wise to help with this?
