Has anyone recorded a crescendo and decrescendo on Garageband’s song?
stevepappas452
Post by stevepappas452 »
I am using Garageband for a long time. I want the sound to be decreased and increased without me modifying it, on a song I recorded on GB. Is there a solution to this?
Re: Has anyone recorded a crescendo and decrescendo on Garageband’s song?
Well, if I'm understanding you correctly, I'd import the file into Audacity. It's easy in that software.
There should be an option to record the mixer movements you do, search manual.
Felainum1977
Post by Felainum1977 »
You can surely automate the increase as well as decrease of volume on your track. You just need to click on the display main track option that you will find under then track menu. This should allow you to have that functionality.
This is why I prefer Garageband as my DAW, but as of now, I am not able to use it. As I am using windows I am not able to run it there. Do you know how this can be done?
stevepappas452
jahnocli wrote: Wed Feb 19, 2020 12:51 pm Well, if I'm understanding you correctly, I'd import the file into Audacity. It's easy in that software.
Okay I will try it in audacity app
cyclearrows
Post by cyclearrows »
I'm using Cubase for a long time. I have Cubase Elements which costs around 100$. I also tested the Pro version and there is nothing I miss in Elements. I also tried Garage Band and I found it quite similar to Cubase.
stevepappas452
cyclearrows wrote: Tue Feb 25, 2020 10:42 am I'm using Cubase for a long time. I have Cubase Elements which costs around 100$. I also tested the Pro version and there is nothing I miss in Elements. I also tried Garage Band and I found it quite similar to Cubase.
Thanks Mate
cyclearrows
You are welcome.
adjessica
Post by adjessica »
stevepappas452 wrote: Mon Feb 24, 2020 11:11 pm
Felainum1977 wrote: Mon Feb 24, 2020 1:01 pm You can surely automate the increase as well as decrease of volume on your track. You just need to click on the display main track option that you will find under then track menu. This should allow you to have that functionality.
Hey @Felainum1977 , I will do it.
There are many DWA apps available for windows. But if you want to use Garageband app for windows, then you need to follow some methods as garageband is macOS app. You need to install any third party application such as VMware or Virtual Box to use garageband app. I found this article on the internet where steps are well explained. Cheers!
https://thegaragebandpc.com/
Garageband is also available for pc? WOw!
stevepappas452
adjessica wrote: Fri May 15, 2020 10:59 pm
Yes, Garageband can be used in windows. But you need to create a virtual MacOS environment in your PC. It can be some by macOs simulators available online.
However, Now i'm thinking to upgrade my monitor setup and purchase a widesceen monitor? I am thinking to go with LG 34WN80C-B monitor. it widescreen and curved dispay.
Found this monitor works well for music production and boost the produtivity.
https://trustedmonitors.com/best-monito ... roduction/
What do you guys think? investing on good monitor will really helpful? Any suggestions should be appriciated. Thanks.
