Best pc build for MOHO
jay123456
Post by jay123456 »
Hello first post here,
Building a pc for Moho to speed up rendering time my budget is 2500£.
I have seen that there is a limit of how many cores Moho reads, 4 or 5, I was planing on getting 12 but I don't think I need that now.
This is my current computer specs;
Core i5 (I5-4570) 4 cores
8GB Ram DDR3 1600 MHz
GeForce GT 755M 1GB GDDR5
1TB HDD
And the pc i want;
AMD Ryzen 9 3950X 16 Core CPU (3.5GHz-4.7GHz/73MB CACHE/AM4)
32GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (2 x 16GB)
8GB NVIDIA GEFORCE RTX 2060 SUPER - HDMI, DP - VR Ready!
500GB Samsung 860 EVO 2.5" SSD, SATA 6Gb/s (upto 550MB/sR | 520MB/sW)
My questions are;
can Moho work with a High powered computer?
what are the max cores that moho can work with?
whats the most efficient way to cut do rendering time?
any windows tip or trick to improve moho ?
Right now i draw my 2D assets in photoshop (.PSD) and then draw facial details as vectors in MOHO along with the Bone Rig tool, i always export using the MOHO Exporter and it normally takes 3 hours(2.30mins 4K) on my current IMAC, currently i have to split my project up so that MOHO doesn't crash this make the rending go up to 4 hours for a 2 mins clip
dkwroot
Re: Best pc build for MOHO
Post by dkwroot »
I think that if you use the Moho exporter program it will use all available cores during the render. This can substantially speed up the render process.
I made a thread a few years ago where users posted their PC specs and compared render times for a common project. As I recall, it seemed that system memory and hard drive speeds made the biggest impact on the performance of the internal renderer. If you use Moho Exporter, then having more than 4 cores should also help out.
jay123456
Post by jay123456 »
dkwroot wrote: Wed Dec 11, 2019 11:49 am I think that if you use the Moho exporter program it will use all available cores during the render. This can substantially speed up the render process.
Do u have a link to that thread?
InfoCentral
Post by InfoCentral »
If I remember correctly there was limit to how many cores Moho uses.
jay123456
Post by jay123456 »
InfoCentral wrote: Wed Dec 11, 2019 5:36 pm If I remember correctly there was limit to how many cores Moho uses.
Yeah 4 for Moho 12
