Switch Layer Slave
Switch Layer Slave
Hi.
I am making a library of characters that require different styles of hair made in switch layers. These hair styles consist of a front layer switch and a back layer switch. (The back layer set so that it folds behind the body for long hair).
Question: is there a way of controlling the back switch layer from the front switch layer automatically? So that when a particular front fringe is selected on the front switch the back switch automatically selects the correct back hairstyle to match?
Many thanks for any ideas.
Cheers
D.K
Cheers
D.K
My store on Renderosity:
Re: Switch Layer Slave
Make one switch a reference of the other and keep the sublayers with the same names, even if you change their contents.
Hi Wes....Uh...of course...sorry. Haven't used reference layers for a while.
Cheers
D.K
Cheers
D.K
No problem. Sometimes I forget about the many uses for references too.
Glad I could help.
Glad I could help.
Hi Wes. Thanks for that. It's working like a charm.
Cheers
D.K
Cheers
D.K
Well....I have a problem. All these reference layers worked great till I started adding a couple of smart bone actions into the mix now they have stopped working. Anyone know how I can repair the broken links?
Thanks
D.K
Thanks
D.K
Ahhh....found it. Sync Channel To Original.
Cheers
D.K
Cheers
D.K
amanandink
I'd be curious DK, if you then reference that model in a scene does the link break? I think it does. and we were looking for a way around it without using scripts
J
J
Hi amanandink. I'll give it a shot a bit later today and get back to you.
Cheers
D.K
Cheers
D.K
Hi amanandink.
I imported the character as a reference into a scene and saved it out. I then closed down moho and reopened, loaded the scene back in and the reference was fine. Am I doing this incorrectly? If you can give me an example of how to break the reference i would be glad to give it a shot.
Cheers
D.K
Cheers
D.K
amanandink
Hey DK, if I have
MASTER FILE
--bone layer
----Original Switch
-----Reference Switch (of Original Switch)
this works fine as expected, the reference is controlled by the original
then if I import the bone layer from the Master File as a reference to a child file, I get this
CHILD FILE
--bone layer (references bone layer in MASTER)
----Original Switch (references Original Switch in MASTER)
-----Reference Switch (references Reference Switch in MASTER, not the Original Switch of the child file)
does that makes sense?
J
MASTER FILE
--bone layer
----Original Switch
CHILD FILE
J
Hi amanandink .
I set up a simple switch reference file like you described, with a reference copy of the switch layer, saved it out then re=imported it as a reference to a child layer of the same file, if that's how I understand your description. It stopped referencing the original master. Is this what you mean by it breaks?
Cheers
D.K
Cheers
D.K
amanandink
ahh are you importing referenced bone layer in to the same file as the original?
Yes...Sorry is that not what you meant?
D.K
D.K
