Is it possible to find out the length of the curve?
FilosoF
Post by FilosoF »
If I have a curved curve, is it possible to somehow get another curve equal to the size of my curved curve?
Maybe there is such a script ?
Re: Is it possible to find out the length of the curve?
Is a curve ever not curved?
Only in Moho. :wink:
FilosoF wrote: Wed Oct 09, 2019 5:09 am If I have a curved curve, is it possible to somehow get another curve equal to the size of my curved curve?
Can you illustrate what you mean? It's a bit unclear what you're asking for.
FilosoF
Post by FilosoF »
Greenlaw wrote: Wed Oct 09, 2019 10:11 am
There is a closed curve for follow paz
The task is to get a straight line equal to the size of that curve, this is necessary for a smooth distribution of objects by follow paz
FilosoF
Post by FilosoF »
synthsin75 wrote: Wed Oct 09, 2019 2:32 pm http://mohoscripting.com/methods/796
This is a good function, but I'm not a programmer, unfortunately, and it’s impossible for me to get a solution to this problem
try this:
https://www.mediafire.com/file/7vr3glc3 ... e.lua/file
put the .lua file in your custom folder e.g. C:\Users\{{your custom folder path}}\scripts\menu\Draw
select one or more points on the curve you want "flattened" then run it as a menu script -- you'll get a line (made of just 2 points) from the centre of your screen towards the right -- you can then move it wherever you want
If that's not what you want / some of the above is not clear, just ask....
FilosoF
Post by FilosoF »
hayasidist wrote: Thu Oct 10, 2019 5:07 am try this:
Thank. This is what is really needed, it optimizes and reduces a lot of time, thank you!!!
Ah, this is interesting. Thanks.
updated to be more resilient to errors and to deal with multiple selected (or partially selected) curves - the "reference line" is now centred on the centre of the curve -- same link
http://www.mediafire.com/file/7vr3glc34 ... e.lua/file
