Hello, everyone,
I want to animate a scene using Moho's physics engine. Having run the the simulation I turn on baked physics to return to the proper rate of playback and to turn my attention towards other elements.
Unfortunately, I don't seem to be able to turn off baked phyiscs to re-run to the simulation. No matter how often I press 'OK' or 'Apply', the box remains checked.
Help!
Marc
Can't turn off 'Use baked physics'
- Víctor Paredes
Re: Can't turn off 'Use baked physics'
Try modifying one of the numbers before pressing apply. Gravity magnitude, for instance.
I think in order to reset the baked physics, the software needs new values to calculate (but that will override any modification you could have made by hands, which makes sense).
Thanks, Victor,
that works. Phew!
Marc
that works. Phew!
Marc
