MacBook Pro OSX El Capitan Ver 10.11.6 Anime Studio Pro Ver.11.2.1:
Is it possible to animate the particle layer settings?
Animate particle settings?
- uncle808us
http://uncle808s.blogspot.com
Re: Animate particle settings?
No.
Depending on what result you want to achieve, it might be possible to animate 2 different particle layers with different settings, then fade one into another.
Also it's possible to animate the particle layer's properties like anything else, so you can change direction and size.
- uncle808us
Thank you. I was hoping to animate the origin size and spread etc. but I can use your work around. Thanks
You need to enable 'Use Base Layer As Source' and then you can animate the size, as well as the shape, of the emitter.
- uncle808us
Ahh.. Yes Thanks...
Glad to help and I hope that works for you.
