Not the first time I've experienced this and I'm assuming not the last either. Anyone know what's going on here? Some weird Moho quirk I'm just not aware of or is this a genuine bug? If so, it's a really REALLY bad one. (12.5)
https://www.youtube.com/watch?v=uuAN96lWaI4
Disappearing Keyframes
Re: Disappearing Keyframes
I'd have to see the file to diagnose it. I've never seen that behavior.
That happens when you have the dimensions of a channel split, and only when you click without moving enough for a real keyframe to be created.
So essentially when dimensions are split it won't set a keyframe unless the value passes a certain threshold? That's unfortunate for me because I set a lot of keys here and there to hold positions longer and fine-tune timing.
Do you know if that's still the behavior in Moho 13?
As long as you have those dimension channels already keyed, so they show, or set to always show, you can just double click the channel on the timeline to set a key for the current value.rafael wrote: ↑Tue Sep 03, 2019 9:18 am So essentially when dimensions are split it won't set a keyframe unless the value passes a certain threshold? That's unfortunate for me because I set a lot of keys here and there to hold positions longer and fine-tune timing.
Behaves the same in v13. This is on purpose, because just clicking a bone would keyframe both X and Y dimensions...in which case, it'd be better to have dimensions joined.
[/quote]
[/quote]
SUPER helpful! Moho separate dimensions is quite different than AE separate dimensions and thus isn't as necessary for my workflow as I had thought. It took your message for me to really appreciate the difference. Also, didn't know about double-click.
You still can't copy/paste a separated key, which is an issue, but I've forwarded it to the support team.
Thanks again!
[/quote]
Thanks again!
You just can't copy/paste the same value, but yeah, that does seem like a bug.
Glad I could help.
