Modified Transform Layer Tool
Stan
Post by Stan »
The modified script contains additional settings in the tool panel - Opacity, Blur, and Visibility. The modification was started by Mike Kelley back in 2009, then I kept updating it for the later versions. And I also changed the bounding box color to green, which helps a lot because it allows to easily distinguish the transform layer from the transform points. The current version works for Moho 12-13.
Download script
Re: Modified Transform Layer Tool
Thanks Stan! I haven't used this mod before but it looks like something I'll use a lot. :D
Shizukuishi
Post by Shizukuishi »
Wow! I was just thinking about this feature these days! Thanks a lot :D
Even with the head in the clouds You can touch the ground
https://marisolpetretto.myportfolio.com/
https://www.linkedin.com/in/marisolpetretto/
mrc
Post by mrc »
Thanks, Stan.
This will save a lot of time!
Marc
You don't agree with the post above? Click here.
www.tricklabor.com/en
