Frame 0 and Frame 1 are different
I've come across a odd thing I'm not able to figure out. I've noticed it in the past, but figured I'd eventually understand it. So far... no luck. The thing is, I can rig a character and after I clear all animation from the document, frame 0 and frame 1 are not the same. There will be differences between the two, that I would have figured should have disappeared when all animation is cleared from the document. So what am I doing wrong?
Re: Frame 0 and Frame 1 are different
Do you have smart bones?
And please don't double post.
I think bone constraints only come into effect on frame 1. That could be a reason.
Marc
Marc
Thank you. That was it. I had a smart bone that created a different look in it's "reset position" than what I was seeing in frame zero. The reset position is the default when animation is cleared from the document. I love this forum.
