Follow path more than 100%
Shizukuishi
Post by Shizukuishi »
I was thinking if it's possible to modify the follow path tool to permit values greater than 100%. It makes sense when you work with a closed path. Currently it's possible if you drag the object, or in the motion graph if you drag keyframes over 100, but every time you click on the path it resets the value, and if you manually insert the percentage it goes back to 100 so it's quite hard to work with.
Hope someone will be interested in this :)
Thanks!
Even with the head in the clouds You can touch the ground
https://marisolpetretto.myportfolio.com/
https://www.linkedin.com/in/marisolpetretto/
Shizukuishi
Re: Follow path more than 100%
Wow! Stan has been super fast and sent me directly the script: https://drive.google.com/file/d/1Ay6ejM ... sp=sharing
Thanks Stan :D :D :D
Wow! I always assumed this wouldn't be possible to make with a script. This is a fantastic and useful surprise.
Thanks again, Stan! And thanks Penny for asking about it :)
