Create Shape tool: Show end points in different color
Hi, I'm working with some very complex shapes (making some experiments to use Moho as a cleanup tool, by the way :) ) and many times I found this problem:
I select several points to create a shape, but the vectors are not closed, so it's not possible to create the shape.
In the image is very evident, but many many times is almost impossible to detect without checking every point very closely.
So I thought about this idea. It would be great if the Create Shape tool would show you every end point selected in a different color, as in this example.
Do you think it is possible to do?
Thank you very much
Re: Create Shape tool: Show end points in different color
Hahaha! this is fantastic. I will use this right now!
Thank you very very much, Wes. This is amazing. Again.
Glad I could help, Victor.
