A Script To adjust the bexier curves in the Motion Graph Editor??
rocken
Post by rocken »
Hello Guys,
I was wondering if there was any script that could make easing in and out key frames much easier without having to mess with the Bezier handles...Something similiar to the Mograph script for After Effects
Shizukuishi
Re: A Script To adjust the bexier curves in the Motion Graph Editor??
Post by Shizukuishi »
There is no script for that, but i found the custom keys script from dkwroot very useful. Once that you understand the concept, if you're patient enough to spend a evening you can set up a bunch of custom keyframes that will help you in a lot of situations. Of course it's not easy like mograph, and not very precise, sometimes you anyway have to adjust handles or sometimes doesn't work at all, but I use it all time and it speeds up my workflow a lot with motion graphics
Even with the head in the clouds You can touch the ground
https://marisolpetretto.myportfolio.com/
https://www.linkedin.com/in/marisolpetretto/
