...That's not meant to happen
catlover8976
Post by catlover8976 »
Firstly I'm sorry but I am using Anime Studio 11, but I'm not a professional and this is all I have at the moment.
Secondly, I've been using Anime Studio since Anime Studio 5, slowly having to relearn things as they changed over and over again. But I have taken a couple of years off as a break to now come back and hoped I'd be able to pick it up again relatively easily but this... I swear I'm not stupid, but this shouldn't be happening, and I can't figure out what I'm doing wrong.
A tail rig should be the most simple rig, to draw bones from one end of a tail to the other, then boom you have a moving tail. I've done it hundreds of times before and yet... Here I am. Confused and lost.
Image Image
This was a point rig.
I made a completely different bone and vector layer to test and replicate it to the same results. What am I doing wrong, what have they changed? It never used to do this.
This was a flexy rig.
Please help, I feel like a noob again.
Re: ...That's not meant to happen
top ones: probably flexibinding - other bones are influencing the points - one set of bones pulling one way and the others refusing to let the vectors go where you want them.
the new rig: at first glance it seems that the vector might not be a child layer of the bone layer????
catlover8976
Former - There's no flexy binding in the whole object, I did it all via binding points.
Later - It is.
ok …
so in the first one - check the point binding is correct?
second one - are you using the bone transform tool on frame 0? that will move the bones but not the artwork.
failing that - if you'd like to upload the AS file I (or anyone else here) could take a look
catlover8976
God I figured it out when I was importing the object to send the file.
Anime Studio I love you but you can be a right twat sometimes. It just randomly changed the Z positioning of the vector object making it freak out. Reset it all and it works normally.
I never touched those parameters or used the 3D once why is it like this.
glad you got it sorted! (take a look at edit > preferences > layers/objects - there's an "auto center new layers" - with that checked, AS will "helpfully" change the origin … might be the answer to the z shift - personally, I keep that off - and I think the default is off in later versions)
