problm in placing script
Deepurana749
Post by Deepurana749 »
there is a script and to install them we have to install tools , resources , and utility file but there is a problm wihle placing utility file all file name are same for example ( rl_utilities ) and if i am going to install different script for different tool there comes a problm because all utility file are same . if i paste them then is says to rename them but if i rename them then they wont run properlly so is there is any solution for that
Re: problm in placing script
You only need one utility file with the same name. All the tools the depend on it will use that one.
Deepurana749
synthsin75 wrote:You only need one utility file with the same name. All the tools the depend on it will use that one.
thanx its worked
