How Can I Achieve Better Automatic Lip-Syncing?
chiefr_suthrland
Post by chiefr_suthrland »
I recently noticed that in the audio settings it says "for more accurate lip-syncing, enter the spoken text below". So I'm basically wondering if there's a certain way I can label my various mouths in my mouth switch layer so that they sync up as accurately as possible with the lines that I type in said section of the audio settings.
alanthebox
Re: How Can I Achieve Better Automatic Lip-Syncing?
Post by alanthebox »
have you tried using the papagayo application? it's not completely automated and it takes a bit more work to set up your mouth, but I've been happy with the results!
Use the Preston Blair phoneme names.
chucky
Post by chucky »
synthsin75 wrote:Use the Preston Blair phoneme names.
This works pretty well, that's the way I do it if I'm doing a quick mouth pass.
it would be great to have a sensitivity slider though as I find you have to 'reduce' a lot of the excessive switches and the mouth 'babbles' a bit.
I actually find it easiest just to manually chug through it manually.
If you want it really good, It is quicker to get it right first time like that than tidying up the automation.
