No Layers Panel
tosiyori
No Layers Panel
Post by tosiyori »
I had to reinstall MOHO Pro 12, now when I open it there os no "Layers panel" This is the same that happened with the previous MOHO, I'm confused, Inserting a MOHO program, still no layers panel.
Re: No Layers Panel
Does it not appear when you select 'Layers' from the 'Windows' menu? Try selecting the command a couple of times. I do this when I can't grab the Title bar of a window because it's off-screen, and closing/re-opening pushes the window back into full view for me.
If that doesn't work, try selecting 'Layers' from under 'Docking'. It's possible that the window is undocked and hidden off-screen. Re-docking it should put it back into view. If you prefer to have the window un-docked, I think un-docking it at this point will put it within the viewable desktop area.
Also, check that 'Save and restore viewport settings' is selected in Preferences. TBH, I think this just saves certain display options but it occurred to me that it might also save window positions. (I haven't tested this to be sure so it's just a thought for now.)
Good luck.
tosiyori
Re: No Layers Panel
Post by tosiyori »
I used your suggestion to "Re-Dock", now the Layers panel is in view.
Thanks muck !
Lew
Re: No Layers Panel
Glad that worked for you. :)
